2002 Chevy Truck
LEE714
Engine Performance problem
2002 Chevy Truck 6 cyl Four Wheel Drive Automatic
when driving runs normal it stalls out about 50 then gets worse like its starving for gas changed fuel filter runs normal then it hapens again only on warm days
changed the fuel filter could not blow threw it but waited a little while then i could blow threw it added heat to it
Mar 17, 2009 at 3:48 AM
RACEFAN966
  • 5,029 POSTS
Ok you did change the fuel filter anyway right? Now what needs to be done is a fuel pressure test. Need to know what the fuel pressure is. Get back to me and we will go from there.
Mar 17, 2009 at 4:01 AM
