2001 Tahoe Front End Shakes
CPGIBSON7
I have a 2001 Chevy Tahoe, 2WD, 135,000 Miles. Front end seemed loose and was told by dealer that tie rods needed replaced. I had this done and all semmed OK. Now when I hit a bump, front end shakes really bad, at highway speeds. It also pulls to the right, all the time. Any ideas on what could be wrong?
May 7, 2007 at 10:53 AM
SERVICE WRITER
  • 9,123 POSTS
You best get the front end up and check for any play before you really have a problem. Whith the wheels off the ground grab each wheel at the 3 & 9 position and give a push- pull action. There should be NO play. Grab at 6-12 as well. Then 2-8 and 4-10 positions. If no play is found, check back. Also check your tire pressures and make them the same as marked on the driver's door jamb sticker spec.
May 8, 2007 at 1:30 PM
