The code on my code reader indicates that the fuel pressure regulator is bad. How do I locate it and replace it .
Thanks Joe
Apr 11, 2008 at 8:30 AM
MERLIN2021
✓Experienced Mechanic
If you are looking for the fuel pressure regulator and can't find it on the fuel rail, you may have the model that has the fuel pressure regulator in the fuel filter. If your fuel filter has three inlets the fuel filter is the fuel pressure regulator
