2001 Chevy Truck find a fuse for "Tow Mode"
2001 CHEVROLET TRUCK
200,000 MILES • V8 • 4WD • AUTOMATIC
BCAMP0404
Hi there,
Looked at the manual and can not find where the fuse is for the Tow Mode.
Hope you can help....sounds too simple, but I'm stumped.
(my Silverado has three fuse boxes, but I can only find two....one in the engine comp. and one at side of dash)
Brian S. Campbell.
Aug 28, 2010 at 10:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
should have fuse block on the lower left side of instrument panel, a instrument panel wiring harness junction block at lower right side of the instrument panel and then an engine wiring harness junction block on driver's side of engine compartment next to the battery.
if your tow button is not working on the shifter, it is most likely because of a broken wire that runs to the end of the gear shifter. very common issue on this model if silverado. i believe it's an orange wire, single wire than breaks at the base of the gear lever, underneath the plastic/rubbery protector.
Aug 28, 2010 at 12:44 PM
