2000 Suburban steering problem
PROBE2K
I have a 2000 Chevy Suburban 1500 with about 135,000 miles. When sitting still, on hard, dry pavement, or backing slowly out of a parking space, the steering wheel will not turn or is very balky, at best. Sometimes it will only turn about 1/2 turn each way before it hits what sounds like the normal end stops. There is no problem when rolling or on wet pavement. Is it the pump, the steering box, or do I even have a speed sensitive steering? Thanks for any help.
Nov 28, 2006 at 5:09 AM
2CARPRO JACK
  • 11,533 POSTS
write down your VIN # and take it to the dealer,they will be able to tell you if it has speed sensitive steering
Nov 28, 2006 at 7:34 AM
  • 55,647 POSTS
Its sounds like the steering pump is going out.
Nov 28, 2006 at 8:18 AM
