I recently had lower control arm, upper ball joint, lower ball joint, and steering arm replaised. Got back from mechanic w/ steering resevour empty. I filled and now truck wont hardly turn. I tried bleeding lines with tires off of ground and turned wheel back and forth 30times. with same outcome. What is wrong is it possible the mechanic got control arm or steering arm to tight?
Feb 10, 2009 at 12:26 AM
