2000 Chevy Truck won't turn
126,000 MILES • V8 • 4WD • AUTOMATIC
FIXXIT72
Hi.
Turned truck off on friday. Got in to go to work on monday. Turned the starter and a loud "CLANG'. And the engine would not turn. The starter works but the engine will not turn. Took off the serpentine belt to hand turn things. Everything turns but the engine crankshaft pulley. Not a budge.
I know it's bad but before I rip the engine apart I could use some ideas.
B
Aug 17, 2009 at 8:38 AM
WINEBURGER
  • 82 POSTS
i have seen the starter nose break off and lodge between the bellhousing and flywheel. what size engine does it have?
Aug 17, 2009 at 9:21 AM
FIXXIT72
It has a 5.7, v8, auto, 4 wheel drive
would make me very happy if that was the problem.
B
Aug 17, 2009 at 9:33 AM
WINEBURGER
  • 82 POSTS
let me know if it was the starter
Aug 18, 2009 at 2:25 AM
FIXXIT72
Not the starter.
B
Aug 18, 2009 at 9:58 AM
WINEBURGER
  • 82 POSTS
pull the plugs out see if it will turn either direction
Aug 19, 2009 at 12:10 AM
