2000 Chevy Truck turn signal/ brake lights
80,000 MILES • V8 • 4WD • AUTOMATIC
REDBONE4X4
I have a chevy k2500 old body style. My passenger side brake light and rear turn signal do NOT work. my running lights and reverse lights DO work. my hazards also do NOT work anywhere. The brake light on the back of the cab has only the driver side working. This all happened at he same time. Ive heard it could be a turn signal switch or circuit boards but have no idea any help would be great. thanks
Dec 22, 2009 at 9:26 AM
  • 110,244 POSTS
I would start with the flasher. However, before that, using a test light, check to see if you are getting power to the printed circuit board on the tail light assembly. I have seen many of the circuitboard go bad.
Let me know what you find.
Dec 25, 2009 at 4:43 PM
