2000 Chevy Truck security light
2000 CHEVROLET TRUCK
85,000 MILES • V8 • 2WD • AUTOMATIC
MATT61
security light is on an engine turns over but will not start
Mar 16, 2010 at 12:33 AM
2CARPRO JACK
  • 11,533 POSTS
You can try a "Passlock Relearn" and see if it will take.If this doesnt work youmay need to have the PCM/VCM sscanned to see where the communucation is being lost in the security system
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
Mar 16, 2010 at 1:21 AM
MATT61
i have tried this an only lasts a couple of starts.wanted to know if there is anything else i can try before taking to dealer.
Mar 16, 2010 at 1:41 AM
2CARPRO JACK
  • 11,533 POSTS
You can try blowing out the tumbler with computer cleaner (air in a can) to remove any metal shavings that may be interfering with the Passlock being able to read the key.Also be sure thereare no other magnets (Mobil speed pass) or the such on the key ring.Beyond that it may be a computer or key issue
Mar 17, 2010 at 12:48 AM
