OBD II not connecting
179,000 MILES • 7.4L • V8 • 4WD • AUTOMATIC
CWILSON1076
  • 5 POSTS
So I was driving back from the store truck bogged down to a crawl. Had a CEL(check engine light) on due to both banks running lean prior to this happening. After the bog down the CEL disappeared. Took it to a shop and they said that the computer has gone out because they cant get the scan tool to communicate with truck.
Has power to everything.Fuel system is good. Fuses are good s that is why he thinks it is the computer. What would cause the computer to go out while driving?
Dec 7, 2016 at 8:25 PM
HMAC300
  • 48,601 POSTS
it may be the scan tool not the computer, try another one to see if it will give codes auto parts does it for free. if auto parts did it do not believe them and go to a mechanic.
Dec 7, 2016 at 10:36 PM
CWILSON1076
  • 5 POSTS
Yeah i was going to do a hard reset the try a different scan tool i do not see how a computer can just go out while driving. Never heard of this happening.
Dec 7, 2016 at 11:46 PM
  • 55,561 POSTS
This is a common problem and it is usually the scan tool that is at fault.
Please let us know happens so it will help others.
Best, Ken
Dec 12, 2016 at 3:47 AM
CWILSON1076
  • 5 POSTS
I will for sure let you know. Just been too busy to work on it.
Dec 12, 2016 at 7:00 AM
  • 55,561 POSTS
Hey,
Did you ever get the problem fixed?
Best, Ken
Dec 21, 2016 at 10:22 AM
CWILSON1076
  • 5 POSTS
Hey! Well inteyed both my scan tools and both are not hooking up.
My battery is to draines to say for sure or not. I have to charge it and try it again. I also tryed doing a hard reset by disconnecting the battery for a day but like i said it was to drained and one of my scan tools said battery low. I will get back to you and let you know. For the last two weeks I've been focusing my 4Runner and getting it up and running so I have a vehicle to drive back and forth to work. I will keep you posted soon as i figure it out..
Dec 21, 2016 at 7:09 PM
CWILSON1076
  • 5 POSTS
Thanks for checking back with me!
(Dang auto correct ) lol
Dec 21, 2016 at 7:12 PM
  • 55,561 POSTS
Sounds good please let us know what happens.
Best, ken
Dec 22, 2016 at 3:55 AM
