2000 Chevy Truck entended crank
72,000 MILES • V8 • 4WD • AUTOMATIC
TOMMYSCHNEIDER20
My Chevy 2500 HD Classic body style 4x4 with a 5.7 l. V8 has a very long crank time. Fuel pump died 18 months ago, I replaced it and the filter. Truck started great until a couple months ago. Crank time has grown longer and longer over the past couple months. I live in Michigan and the temp has gottten much cooler over the last couple months. I can hear the fuel pump running and stoping like it is suposed to. I cahanged cap and rotor, all plugs, and wires last week, no better on start. Changed crank sensor today, still have problem.
Jan 2, 2010 at 2:18 AM
JDL
  • 16,098 POSTS
Hi, use a gage and check fuel pressure. Sometimes, cycling the key several times before you crank, might help the fuel system, if the problem is a fuel issue? Engine cranking, the pump gets battery voltage. Engine running it gets alternator voltage, there is a difference. I guess you use a block heater?
Jan 2, 2010 at 2:43 AM
