2000 Chevy Truck engine blubbering
2000 CHEVROLET TRUCK
104,000 MILES • 6 CYL • 4WD • AUTOMATIC
69 MARO
I have a 2000 chevy 1500 silverado 4.8L and I'm having issues with every once in a while when I start it up the engine will blubber and sometimes hesitate when pressing the gas pedal. Sometimes it will even stall. I already replaced the fuel pump, and that wasn't the cure.
Feb 24, 2008 at 12:52 PM
PHALYNX69
i read an article the other day about this problem and it says that a faulty throttle position sensor can cause this very problem that is the only thing i have not changed on my truck i believe it is about $35 at autozone so that is my next step
Mar 4, 2008 at 3:09 AM
MASTERTECHTIM
  • 4,750 POSTS
check for fuel at the vacuum hose at the fuel pressure regulator and if fuel is ther replace it
Mar 4, 2008 at 3:22 AM
