2000 Chevy Truck BLEED FUEL SYSTEM REPLACE FUELFIITER
143,000 MILES • V8 • 2WD • AUTOMATIC
EDDIESEGURA
HOW DO I BLEED THE FUEL SYSTEM FOR MY TRUCK
WHAT FUSE NEEDS TO BE TAKEN OUT
Jul 18, 2009 at 10:07 AM
DR LOOT
  • 2,311 POSTS
I'm having a hard time understanding your position on what you want to do and why you want to do it. Is it truck a diesel? if it's a gas vehicle you will find the fuel pump relay on the right side of the firewall behind the fuse and relay cover, looked at your manual it will tell you which ones the fuel pump relay take a wire and jump it that will activate your fuel pump, now if it's a diesel that's a whole different story.
Jul 25, 2009 at 7:56 AM
