2000 Chevy Truck
ART ANDERSON
Engine Mechanical problem
2000 Chevy Truck V8 Four Wheel Drive Automatic
My truck has a miss fire, can you tell me all the possible reason as to why this can happen and what to check to fix this problem?
Sep 11, 2010 at 7:44 PM
WRENCHTECH
  • 20,760 POSTS
Have you determined which cylinders are causing the problem?
Have you checked the computer for any stored codes?
How many miles on the vehicle and have any of the ignition components been changed and when?
Sep 12, 2010 at 12:07 AM
DODGEPROBLEMS
  • 5 POSTS
Likely a fowling plug, wire, or coil. Could possibly be a fuel problem. First, bring it to Advance or Autozone and see if you can pull a code and go from there.
Sep 12, 2010 at 1:32 AM
