2000 Chevy Impala, Istrument panel lights dim out
HITOP
It's a 2000 Chevy Impala with a 3400 engine with approx 81,000 miles.
When starting the instrument panel lights up, then you hear a click, and the instrument panel lights dim out. all the other guages work, no check engine light, the instrument panel lights just fades out. Can you please help....Thanx
Jan 15, 2007 at 9:32 PM
SERVICE WRITER
  • 9,123 POSTS
Is the panel dimmer switch on low? Turn it up all the way and try it.
Jan 15, 2007 at 9:43 PM
HITOP
The Dimmer is all the way up, it only lights up when the veh initially starts, then it sounds like a relay click, then it dims out.
thanks for the response Paul
Jan 15, 2007 at 9:55 PM
SERVICE WRITER
  • 9,123 POSTS
Your welcome, I don't know that I can help on that, I looked over the wiring diagrams to see if anything jumped out. (Kinda like when a car quits, the first thing you do is open the hood like it will jump out and tell you :lol: ) I'm not a good electrical guy, but will take another look tonight after work to see. Maybe someone will add there 2 cents before then :)
Jan 15, 2007 at 10:13 PM
SERVICE WRITER
  • 9,123 POSTS
Go to your A/C accuumulator, at the bottom of it there is a wiring harnes that may have been damaged from chafing against the mounting ring of the accumulator. That is all that I found that my abilities can provide.
Jan 16, 2007 at 9:20 AM
HITOP
I'll definitely check that out...
Thanks again Paul
Jan 17, 2007 at 12:02 AM
