To test the valve the only real thing you can do is test the solenoids wiring for shorts and opens. First remove the electrical connector, then read the connections to verify that you have continuity(low resistance) between them. Next read each pin to ground to see what resistance you get(should be very high( high resistance = no ground, low resistance = ground).
SPONSORED LINKS
Monday, February 26th, 2007 AT 5:14 AM
