2000 Blazer LS 4x4 Noise
PTWARRIOR92
I own a 2000 Chevy Blazer LS 4x 4 2 door with the 4.3 V6 automatic with air. Lately in the morning when I start to drive it I hear a clicking and small grinding noise that seems to be coming from the right front tire/right front engine compartment area (alson sometimes sound like a baseball card that was stuck in the spoke of a bicycle rim). It gets louder when I drive faster and dissappers when the car comes to a complete stop. The only thing that seems to correct this is when I shift it into 4 wheel drive and then back into 2 wheel drive. I have had the car to the dealership 4 times now and they cannot seem to locate the problem (the car only has 44,000 miles on it and is still under warrenty). They have told me they have checked the brakes and abs system along with the 4 wheel drive system and all look good (although right now I am questioning that). Any ideas as to what may be causing this as right now I am at a total loss. There are no modifications made to this car, and the most recent work done to this was a new serpintine belt. Thanks for your help.
Jan 30, 2007 at 6:51 AM
RICKROSE21
Hey, I would get the vacuum portion of you 4x4 checked because this is happening to me on my 1998 blazer and the mechanic fixed it temporarily by cutting a vacuum hose under the hood on the left side of the engine compartment. that fixed the problem but if I want to go into 4x4 now I have to take the plugs out of the hose that he cut and put them back together. there is a module for this to fix it but I have not had a chance to look that closley at it because I just got back from my trip today. good luck
Feb 11, 2007 at 2:55 PM
