rear lights and front markers out?
SCHNAUZEREARS
The problem started when I noticed 1/2 of the radio lights went dark. This lasted for a few weeks. Then one evening while driving, I heard a click and saw that all the dash and radio lights went out. I then discovered that the tail lights are out (not the brake lights) and the front marker lights are out as well (not the headlights).
I checked the manual for the fuse box locations and it says there are three. Each box has a description of each fuse and what it controls. Fuse #1 on the fuse panel located on the right side of the glove box says it controls the instrument panel lights and cigarette lighter. The fuses is fine and the cigarette lighter works, but no panels lights.
Also, the turn signal and brake lights work, but as I mentioned, the rear marker and front marker lights do not work.
Has anyone seen this type of problem and how do I fix it?
Mar 18, 2007 at 7:20 AM
AMNORTO
  • 17 POSTS
It could be a relay gone out wich is usually located in the fuse box under the hood, a way to check to see if one has went out is to pull every relay out ( only one at a time) and see if the metal prongs have burnt marks on them. If you still cant locate the problem check with some mechanic shops in your area some might test your electrical for free.
Mar 22, 2007 at 4:43 PM
SCHNAUZEREARS
[quote:c2f2dbd55e="Schnauzerears"]I have a 3.1L 1999 Chevy Lumina. The problem started when I noticed 1/2 of the radio lights went dark. This lasted for a few weeks. Then one evening while driving, I heard a click and saw that all the dash and radio lights went out. I then discovered that the tail lights are out (not the brake lights) and the front marker lights are out as well (not the headlights).
I checked the manual for the fuse box locations and it says there are three. Each box has a description of each fuse and what it controls. Fuse #1 on the fuse panel located on the right side of the glove box says it controls the intrument panel lights and cigarette lighter. The fuses is fine and the cigarette lighter works, but no panels lights.
Has anyone seen this type of problem and how do I fix it?[/quote:c2f2dbd55e] I have fixed the problem and I would like to share the answer as this could help others avoid the time and confusion I have gone through trying to narrrow this down without dumping hundreds of dollars into it.
First I want to clarify the problems I listed in the original post. The radio being 1/2 lit originally was due to a blown bulb within the radio, so that was totally unrelated to the fuse problem.
Second, thanks to Amnorto's post in response to my post, I began to look for the relay in question. This is when I discovered that the Lumina Owner's Manual has an incorrect description of a fuse that turned out to be the problem fuse which led me to the solution I am about to describe. The fuse that controls the parking lamps is labeled correctly ON THE FUSE BOX (under the hood on the drivers side) but is MISLABELED :evil: (deliberately?) in the manual as "HEADLAMPS". That is why I missed it in the first place. Now the fix.....
I then replaced the fuse, only to have it blow within a few minutes. So now the wires in question belong to the front and rear markers and the dash lights. This is when I realized that 1 year ago I had the front driver side marker light socket replaced during my annual NYS Inspection. So this is where I started to look first (I also kept the receipt and description of work done and this helped to cut time off of this).
So, I took the screw off of the lamp cover and took the socket out of the lamp housing AND THEN SAW ALL THE WATER THAT WAS IN THE HOUSING RUN OUT ONTO THE DRIVEWAY. The circuit was obviously shorting out as the water the wires to "cross" when the headlamps were turned on. The bulb was still in the socket with minimal corrosion (the buld and socket are one piece, unlike the headlamps) but was drenched. So I took a piece of kleenex and stuffed it into the lamp housing to absorb all the water out, then found the small crack in the housing where the bulb fits in an fixed that with super glue. I then pulled the passenger side housing to inspect that (which has never been replaced) and found that the bulb had a silicone sealant between the socket and the glass, obviously to protect it from water. IF THE GARAGE WHO FIXED THIS LAST YEAR WOULD HAVE APPLIED SEALANT TO IT, IT MAY HAVE PREVENTED THE PROBLEM, BUT THE POOR DESIGN WOULD PROBABLY HAVE CAUGHT UP WITH IT EVENTUALLY. So I went back to the driver's side took my wife's hairdryer (she was very helpful) and thouroughly dried the buld and socket and put a silicone sealant between the socket and edges of bulb. Then I put a new fuse in and tested before I reassembled and now it works fine. When I reassembled, I realized that the design of this bulb/socket/housing was very poor, as there is no rubber gasket to prevent water from entering the housing. So, I took some electric tape and wrapped the housing area where the bulb locks in (after I locked in the bulb) and wrapped it to at least try to protect this from happening again and put the housing in place. Now it is finally fixed and I can drive safely at night and avoid a possible traffic stop and fine by the Police. Hope this helps all you Lumina Owners! :D
Apr 1, 2007 at 3:42 AM
SKIZOOM
You have a light shorting out somewere and is causing the master light switch to shut down I would bet it is one of the sockets on one of the marker lights on the fenders 1 of the two red rears or 1 of the front 2 ambers .. First you need to remove the headlight switch ..let it sit unplugged for several days to see if it resets ..After waiting plug it back in to see if you have the lights back then start checking those marker light sockets /lights for shorts
Apr 18, 2007 at 12:31 PM
