1999 Chevy Truck Starter Tests ok, truck wont crank
1999 CHEVROLET TRUCK
BSUSSMAN
Engine Performance problem
1999 Chevy Truck Four Wheel Drive Automatic
Chevy K3500/350V8
The starter bench tests ok in a good test rig. I saw it. The gear went out and turned.
Engine turns manually.
I hear the starter gear turning but it is not engaging the flywheel.
Like the solenoid isn't working right.
What do I look at next?
May 9, 2008 at 4:13 PM
I hear the starter gear turning but it is not engaging the flywheel. Is it making a whining noise?-if not the starter overrunning clutch is slipping no time to rebuild replace it-
May 9, 2008 at 4:21 PM
BSUSSMAN
[quote:5c46983211="rasmataz"]I hear the starter gear turning but it is not engaging the flywheel. Is it making a whining noise?-if not the starter overrunning clutch is slipping no time to rebuild replace it-[/quote:5c46983211]
No whine. just a healthy rotation.
If I understand, you say it isn't worth it to rebuild, I should just replace it?
May 9, 2008 at 4:27 PM
Its new and if there's no physical contact with the starter drive pinion and the flexplate, it needs shimming-Shims are used to get the drive pinion closer to the flexplate-
May 9, 2008 at 10:22 PM
