1999 Chevy Truck is it worth it?
13,000 MILES • V8 • 4WD • AUTOMATIC
ERICM123
i have a 99 2500 and the transfer case is burnt up, and i was thinking about pulling it out myself and bringing it in to be rebuilt is this a hard task to do?
Jan 13, 2010 at 9:38 AM
JONZIE33
[quote:5bed9176f3="ericm123"]Drive Train Axles Bearings problem
1999 Chevy Truck V8 Four Wheel Drive Automatic 13000 miles
i have a 99 2500 and the transfer case is burnt up, and i was thinking about pulling it out myself and bringing it in to be rebuilt is this a hard task to do?[/quote:5bed9176f3]removing the transfer case inst to bad if ur mecincaly inclined u must remove the transmission with trnsfer case attaced then seperat them on the ground uslally there pretty easy to do there about 6 or 8 bolts that hold it to gether u will need a new gasket to reseal it.. unless u know what ur doing i would try and rebuild it your self but u can take it out
Jan 18, 2010 at 2:23 PM
