1999 Chevy Truck brake lights
JCHEMA_13
  • 6 POSTS
Electrical problem
1999 Chevy Truck V8 Two Wheel Drive Automatic
i have all my brake lights working in my rear of the truck but my brake lights dont come on. also i was wondering where you got that picture of the wiring diagram and if you could send it to me so i can trace out the brake switch wiring
Jan 11, 2010 at 9:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
what do you mean you have them working but they don't come on? if they aren't coming on then they are not working properly..?
Jan 11, 2010 at 9:32 AM
JCHEMA_13
  • 6 POSTS
my park lights work as do my back up lights and my turn signals, but when you press the brakes nothing happens even my third light works just not my left and right side. i have replaced the stop light switch and the turn signal switch as well as the circuit board where you put the lights on. i am trying to trace the wires but caint seem to find a diagram to follow the wires off the stop light switch
Jan 11, 2010 at 10:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Oh, ok. Well I have the wire diagram but it is extremely large so I can't post it because it would not be readable. I can post the section with the stoplight switch though.. it only has 2 wires , 1 orange and the other white. The orange wire goes to the STOP LPS fuse while the white wire runs to the CHMSL Fuse & the VEH STOP fuse. Have you checked all 3 of these fuses?
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1423.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_420.jpg
Jan 11, 2010 at 11:01 AM
JCHEMA_13
  • 6 POSTS
i have checked all fuses and they are good also my brake light switch has more than two wires. a orange that is hot a white the when brake is depressed powers up. a green that runs to the turn signal switch.i aint sure about the rest but i think one runs to the with that allows you to move from park to drive. the white wire i followed it up towards the fuse panel where it splits one towards the fuse and three towards the fire wall. can you send the diagram to my email to where i can see it or is therer a place to go to find exactly where the wires are going.
Jan 11, 2010 at 11:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
see if this link has what you are looking for..
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Jan 11, 2010 at 11:18 AM
JCHEMA_13
  • 6 POSTS
i went there and saw the diagrams but still am lost. is there an added relayand i know that the turn signal switch allows the brake light to be lit but is there a place to get a diagram for that. like i said pior i have replaced the turn signal switch but still nothing. is it possible to run new wires and if so how is it done
Jan 11, 2010 at 11:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if there is a relay on yours it should be labeled "Brake Lamp Relay" and located in the underhood fuse / relay center, but I believe this relay only controls the high-mount stop lamp. is your cruise control working? when the cruise module fails so do the brake lights.
Jan 11, 2010 at 12:01 PM
JCHEMA_13
  • 6 POSTS
well i know the fuse box under the hood is at but i dony have the lid that tells you what is what. also where would my cruise control box be located at
Jan 12, 2010 at 12:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
your cruise control module is in the left rear of the engine compartment, attached to the firewall.
Jan 12, 2010 at 1:32 AM
JCHEMA_13
  • 6 POSTS
ok i found it but how would this cause my brake lights to fell and if i unplug it should they work
Jan 12, 2010 at 5:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
runs though same circuit..is your cruise control working?? if it is then it is not the cause of the brake lamps.
Jan 12, 2010 at 5:47 AM
