1999 Chevy Prizm
DYXTER
I have a 99 Chevy Prizm. It has about 92K miles. As I drive, it makes a knocking sound as if the sound was coming from the driver's side front end. Also It is very distint when I come to a stop. I can hear a squeaking noise and the knocking. I'm thinking it could be the cv joints but I'm need sure. Please advise.
Jan 18, 2007 at 10:53 AM
CLEAVAGE4U
  • 69 POSTS
Daddy sas those nosies can be tricky sometime to figgir out. He thinks you need to splain more about them noises. Like maybe it's when you go over bumps, or maybe when your turnin. MAybe if you tell us more maybe we can figgir it out. :wink:
Jan 18, 2007 at 11:15 AM
DYXTER
The noise can be heard while drive on smooth surface and particularly noticable when braking. It also seems to make some noise when turning too.
Jan 18, 2007 at 12:06 PM
CLEAVAGE4U
  • 69 POSTS
Maybe you could take a peak under that car and look at the Rubber boots that cover the axle shaft joints and see if they are leakin bad or ripped open.
When you do the brakin, do you feel anything or are just hearin' it?
Does the noise make any changin when you are turnin left instead of right, or vicey versey?
Jan 18, 2007 at 9:49 PM
