1999 chevy express van
JOCKEYMIKE
  • 6 POSTS
5.7 starter flies out against the flywheel in p or n checked the ignition switch starter and starter relay what could it be ?? it runs fine in d123 or reverse stummped in palmyra pa thanks
Jan 4, 2006 at 1:25 PM
JOCKEYMIKE
  • 6 POSTS
does anybody have a clue
Jan 4, 2006 at 2:22 PM
JOCKEYMIKE
  • 6 POSTS
bump :?:
Jan 5, 2006 at 11:47 AM
EXPRESSVANILLINOIS
[quote:cf7437c196="jockeymike"]5.7 starter flies out against the flywheel in p or n checked the ignition switch starter and starter relay what could it be ?? it runs fine in d123 or reverse stummped in palmyra pa thanks[/quote:cf7437c196]
Exact same thing happened to me traveling home after holidays, 2002 5.7 starter flys out in p or n... later that same trip, starter flys out also in d123; this burned out the starter... new starter flys out also, but now only in p or n. I have not solved this one yet...
My understanding is that the only components involved here are ignition switch, starter, starter relay, and Park/neutral sensor.
Can anyone shed light on this?
Jan 3, 2008 at 7:48 AM
