1999 Chevy Camaro - Issues
IMAGINE9103
1999 Chevy Camaro v6 93,000– When I start it in the morning it jumps like it wants to take off, after it starts the rpm gauge is a 1 when in park position and it vibrates slightly. It makes a rough noise coming from the engine, as though you were driving on a dirt road. While driving down the highway you can feel a sputter in the gas pedal at 55-65mph. On turns the car loses control. Got a pre alignment and alignment check, all front suspension parts were solid; no angles were out of specification. Another problem is I added antifreeze to the radiator and coolant recovery tank but my heater doesn’t shoot any heat out. Is it the thermostat? I noticed when I switch the heater to on position the car changes (you can feel it in the gas pedal) or when I change from low heat to high heat, which neither produce heat.
Feb 18, 2007 at 10:51 AM
KIN CHAN
  • 453 POSTS
this sounds like an electrical issue...needmore info...mostl likely u need a professionalto trouble shop electrical shorts or pwr & grd area to pin point ur problem...
Feb 21, 2007 at 8:49 PM
2CARPRO JACK
  • 11,533 POSTS
Check to see if the A/C is coming on when you select heat. Remember that the A/C comes on in defrost mode
Feb 22, 2007 at 12:31 AM
