1999 Chevy Astro van
HUGNFUN
Hi
I have a small (I hope) electrical problem with this van. For some reason when the van hits a bump or pothole in the street, it totally shuts down all electrical, and all power. I'm almost sure and hopeful that it was the ground cable that goes to the battery, because it just recently jarred itself free, and now is completley disconnected. Could the electrical have been the loose cable? Or should I check something else?
Mar 15, 2007 at 6:03 AM
ASTRO
  • 12 POSTS
Do you have the 4.3L engine? I had a similar problem.
I'd hit a bump, and the van would die. There is an A/C line that runs across the top of the engine, and rubs against the wire harness going to the ignition coil. Remove the engine cover, start the van, then wiggle the 4-wire harness attached to the coil. If the van dies, there's you problem!
Mar 19, 2007 at 8:51 AM
HUGNFUN
Yes it does have a 4.3. I will look into that A.S.A.P. Thanks for the advice.
Apr 8, 2007 at 3:15 AM
ASTRO
  • 12 POSTS
Also check the harness to the ignition control module mounted to the coil bracket for same.
Apr 14, 2007 at 8:17 AM
