1999 Chev Silverado - Loss of all electrical power
REPAIRGUY
I have a 1999 Chevrolet Silverado K1500. Intermittently it will loose all electrical power while i am driving down the road. (Everything on the dash goes out just like the battery was disconnected.) After a short period of time, 15 seconds or so, all power returns and the truck can be restarted. Sometimes it will happen only once in a trip, other times more. Could this be an ignition switch problem? All electrical connections are clean and tight. :)
Mar 2, 2007 at 6:51 AM
CHEVY22
  • 1,375 POSTS
have you checked in the fuse box for any corrosion ,???
while your at it i would check the battery ground wire and the ecm connectors , pull those and see if there is corrosion in there and get back to me
thanks jim
oh you may have to pull a couple of fuses at a time to really see in the box
Mar 2, 2007 at 3:41 PM
