1998 Chevy Truck Water Pump
1998 CHEVROLET TRUCK
RANDALLLSMITH
Engine Mechanical problem
1998 Chevy Truck V8 Four Wheel Drive Automatic
I am changing out my water pump. The fan/clutch assembly is attached to the pump shaft directly by a 1" nut screwed onto the shaft. The problem is that the pump shaft is free spinning. How do you hold the pulley/shaft still so as to unscrew the fan/clutch assembly off the shaft.
Nov 28, 2008 at 10:27 AM
DOCFIXIT
  • 18,828 POSTS
I use a strap wrench around pully
Nov 29, 2008 at 12:39 PM
RANDALLLSMITH
Thank You very much
Dec 1, 2008 at 11:10 AM
