1998 Chevy Truck surges
160,000 MILES • V8 • 2WD • AUTOMATIC
JOHNRYMEL
I have a 1998 chevy pickup and it started to stumble and hessitate if you hold it steady. it will surge going down the road. i have replaced the fuel filter but did not fix it. i cleaned the IAC valve and checked vaccum lines for leakes but no change. thanks for the help .
Jan 16, 2008 at 6:24 AM
PEAR69
  • 1,482 POSTS
Sounds like a sticking exaust valve or a failing head gasket.
Jan 16, 2008 at 7:50 AM
DAVEW741
  • 5 POSTS
[quote:10c8c1f4ff="pear69"]Sounds like a sticking exaust valve or a failing head gasket.[/quote:10c8c1f4ff] it is the egr valve
Jan 19, 2008 at 12:39 PM
JOHNRYMEL
[quote:dfd3084dcd="davew741"][quote:dfd3084dcd="pear69"]Sounds like a sticking exaust valve or a failing head gasket.[/quote:dfd3084dcd] it is the egr valve[/quote:dfd3084dcd]
i think i got it figured it out. i suspected bad gas and i poured some b12 in it and immeditely seen a difference but still some hesitation. i am gonna try to flush the fuel system and hopefully that will fix it for good. thanks everyone for the help.
Jan 20, 2008 at 11:52 AM
