When pressing on the fuel petal lightly, vehicle will get up to speed (55). When pressing more firmly (not flooring it) RPMs drop and vehicle starts to slow. Have replaced the fuel filter and air filter. Fuel pump was installed 3 months ago. When in "Park" and pressing fast, RPM will drop. If vehicle is turned off for 10 - 20 seconds, will run fine for about 2 miles then start doing it again. Could it be the EGR Valve or the Catalyc Converter? What do you think? There are no engine codes and the light is off
May 5, 2008 at 12:42 PM
