You can try replacing the fuel filter, making sure there is no vacuum hoses off or broken, you can check the fuel pressure make sure it's correct, or it may have a bad coil, that should keep you busy let me know what you find out
SPONSORED LINKS
Friday, June 19th, 2009 AT 10:46 AM
