1998 Chevy Truck remove rotor
BIMBOHELP
Brakes problem
1998 Chevy Truck V8 Four Wheel Drive Automatic 170k miles
1998 k3500 4x4 SRW
How does the front rotor get removed?
May 1, 2010 at 8:55 AM
HMAC300
  • 48,601 POSTS
after you pull the caliper and bracket off, you need to pull the wheel lock off then the large nuts that hold the wheel bearing on . then the rotor should come righ toff.
May 8, 2010 at 2:04 PM
