1998 Chevy Truck REAR END NOISE
250,000 MILES • V8 • 2WD • AUTOMATIC
KATHICHAPMAN
THE REAR END MAKES A WHINNING NOISE WHEN DRIVING, BUT STOPS WHEN YOU LET OFF THE GAS. I REBUILT THE REAR END AND THIS DID NOT FIX THE PROBLEM WHAT ELSE COULD BE MAKING THIS NOISE IT IS GETTING VERY LOUD
Feb 27, 2009 at 9:58 AM
DCS1998
  • 41 POSTS
[quote:6227445101="KathiChapman"]Noises problem
1998 Chevy Truck V8 Two Wheel Drive Automatic 250000 miles
THE REAR END MAKES A WHINNING NOISE WHEN DRIVING, BUT STOPS WHEN YOU LET OFF THE GAS. I REBUILT THE REAR END AND THIS DID NOT FIX THE PROBLEM WHAT ELSE COULD BE MAKING THIS NOISE IT IS GETTING VERY LOUD[/quote:6227445101]
To much backlash.
.007-.010 mesured off the ring gear with a dial indicator.
When you change out bearings and such....you have to re-shim for the correct lash while keeping a good gear patern with the ring and pinion.....
David
Feb 27, 2009 at 4:00 PM
