1998 Chevy Truck Motor Problems
1998 CHEVROLET TRUCK
209,000 MILES • 6 CYL • 2WD • MANUAL
ADAMNOS1985
When i first turn my truck on it seems to run normal and drive normal. But the more i drive it aftarwards is when the problem occurs and gets worse and worse. It starts to bog down the more gas i give it and cut out, but only after i drive it for a little while. When this happens i turn the truck off and when i turn it back on, it seems to be back to normal for a little while longer. I have changed spark plugs, distributor cap and rotor, both oxygen sensors, control module, and the coil but none of this has helped so far. I really hope someone can help me figure this out.
Jul 18, 2010 at 2:42 AM
DR LOOT
  • 2,311 POSTS
you fail to mention that you check the fuel pressure or replace the fuel filter
Jul 20, 2010 at 5:32 PM
ADAMNOS1985
yes i did replace the fuel filter
Jul 23, 2010 at 7:38 AM
DR LOOT
  • 2,311 POSTS
after replacing the fuel filter tell me what the fuel pressure was.
Jul 23, 2010 at 11:44 AM
