1998 Chevy Truck Motor Problems
89,000 MILES • V8 • 4WD • AUTOMATIC
REYNOLDS88
My motor seems to be misfiring. I don't know if this could be because one of my spark plugs, ir if maybe my cat is plugged? if i could get some direction on what to do to fix my problem that would be awesome, thanks
Apr 8, 2010 at 8:42 AM
INTERNETMECHANIC
  • 700 POSTS
How long since a tune-up? Use a gage and check fuel pressure. Check for any applicable trouble codes. At the least, you need an obd2 code reader. Some of the national brand autostores used to check PO codes for free. You can call and ask.
You can use a pressure gage in place of the front 02 sensor. Raise the rpms to 2K or a little better, if the pressure reading exceeds 1.25psi, the exhaust is restricted, so says MOD.
Apr 8, 2010 at 9:04 AM
MERLIN2021
  • 17,250 POSTS
First thing is, is the service engine soon light on?
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
If the light is blinking, it means engine misfires possible damage to the Catalytic converter...service it right away!
Apr 8, 2010 at 9:05 AM
