1998 Chevy Truck heater fan
1998 CHEVROLET TRUCK
60,805 MILES • V8 • 4WD • AUTOMATIC
RAZZBIRD
the heater/AC fan will not work at any speed setting
Jan 30, 2008 at 8:45 PM
SERVICE WRITER
  • 9,123 POSTS
Most likely blower motor is bad. Check for power at the plug going to the motor. Sometimes you can tap on the motor case and jar it to temporarily work and help confirm.
Also check the fuse for that circuit, and the switch although less likley may be the source.
Jan 30, 2008 at 8:49 PM
