camshaft position sensor location
1998 CHEVROLET TRUCK
51,347 MILES • V8 • 4WD • MANUAL
HARYDOG49
Where is the camshaft position sensor located I cant find it?
Jan 22, 2009 at 7:19 AM
DOCFIXIT
  • 18,828 POSTS
The sensor of the camshaft position is inside the distributor here is a diagram to help you see how to change it below.
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
Jan 22, 2009 at 7:31 AM
TRINADALE
how to get sensor out of distributor
Feb 26, 2021 at 9:59 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
just remove screw and remove the sensor from the distributor.
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_353.jpg
