1998 Chevy Truck auto v push button transmission
11,000 MILES • 6 CYL • 4WD • AUTOMATIC
LARIEGAN
I need to replace my transmission and my truck has a transmission that goes to 4 wheel drive automatically, can I use a transmission that has a push button to start 4 wh drive in it? Would the truck run?
Jun 25, 2009 at 9:02 AM
2CARPRO JACK
  • 11,533 POSTS
I would imagine the trans would be ok, as long as you use the transfer case from the original trans.The trans doesnt have anything to do with auto-4wd, it is all done in the transfer case. Just to be sure, compare the main plug that goes into both trannies to be sure the pin location and count is the same
Jun 26, 2009 at 12:55 AM
