1998 Chevy Truck 5.7 L water in the oil
1998 CHEVROLET TRUCK
204,000 MILES • V8 • 2WD • AUTOMATIC
BIPEMECH
I am considering buying a 1998 c2500 chevy with a known problem, it is getting coolant in the oil, I know this is classic blown head gasket, cracked head, or cracked block, however I have also heard this can be from a bad intake gasket, Is that true??? Obviously I want to keep the repair costs to a min.
Thanks
J
Feb 14, 2008 at 11:51 PM
2CARPRO JACK
  • 11,533 POSTS
I would wager on the intake gasket doing it. Those engines do crack heads (thin wall castings) , but I cant recall seeing that cause water in the oil before, usually water consumption, miss in the morning.
Feb 14, 2008 at 11:54 PM
