1998 Chevy Tahoe Front Differential Vent Leak Fix
AUSTS
I have oil coming out of the vent tube on the front differential. No oil had been added before this problem started.
Feb 22, 2007 at 11:42 AM
CHEVY22
  • 1,375 POSTS
is the oil pumping out or just a small drip??
oh i just remembered there is an updated tube assembly for this problem
Feb 22, 2007 at 12:28 PM
AUSTS
the oil pumps out when it does it.It doesn't do it all the time.But when it does it soaks the driverside of radiator and steering gearbox. Thanks in advance for your help
Feb 24, 2007 at 8:44 AM
CHEVY22
  • 1,375 POSTS
i would suspect the check valve in the tube may have failed as i sated before , let me know if you need anymore help i get an email when the post is replied to
jim
Feb 24, 2007 at 8:54 AM
AUSTS
thanks for your help i will try this and let you know of the outcome
Austin
Mar 2, 2007 at 3:27 AM
CHEVY22
  • 1,375 POSTS
please do ,
thanks
jim
Mar 2, 2007 at 4:51 AM
Suggested Repair
Inspect the front differential vent tube and its check valve. The expert suspects a failed check valve and notes an updated vent tube assembly for this intermittent oil pumping issue.
Conversation Summary
The owner of a 1998 Chevy Tahoe 4X4 reports oil pumping intermittently from the front differential vent tube, soaking the driver side of the radiator and steering gearbox, with no oil added beforehand. The expert suspects a failed check valve in the vent tube and mentions an updated tube assembly. The owner plans to try that repair and report the outcome.
