Oil pressure gauge is stuck on 80
LOCOLIZARD
oil pressure gauge is stuck on 80. Any clues as to why and/or solutions?
Dec 9, 2006 at 7:47 AM
SQM
  • 6,383 POSTS
This could be due to a faulty pressure sensor or a bad stepper motor for the gauge.
The oil pressure sensor is located on the top part of the engine, behind the distributor cap.
Test the sensor by using at multimeter. If the resistance reads out of limit for the sensor that it is a bad sensor and needs to be replaced.
https://www.2carpros.com/articles/high-oil-pressure
Oct 20, 2021 at 6:52 AM
