i have a 1998 Chevy Cavalier and my head lights do not work and only one high beam work can any one help me fix this thanks
Mar 2, 2007 at 12:36 PM
Confirm the headlight bulbs and fuses are good. If the problem remains, test the headlight relay and multifunction switch.
The owner of a 1998 Chevy Cavalier reported that the headlights do not work and only one high beam works. After the owner said the bulbs and fuses had been checked, the expert suggested the headlight relay and multifunction switch as the next likely causes.
