1998 Chevy Cavalier 2.2L Theft Mode Issue
1998 CHEVROLET TRUCK
PHILO
  • 6 POSTS
Ok here's what happened I was coming home from work one night and had to go through somewhat high water. The car went through the fine did not shut off stutter or anything similar.
The next day when I went to get in the car the fan was running and the car was off we did try replacing the relay no luck it would still turn on randomly with car off. We did try another fan which was known to be good same issue. We ended up wiring the fan directly to the windshield washer fuse and that issue corrected itself.
Now my issue is this when the car sits for 2 hours or more it goes into a theft mode like state. I have to leave the key in the on position after 1 or more failed starts and when I hear the fuel pump kick in turn the key and i'm good to go. One other oddity the check engine is always on and on the dash where you gear is indicated by an orange light most of the positions don't light up since the water incident. Car drives fine all gears work. I've noticed that when I get it to start the first time the theft mode will stay on if I turn it off then back on the light will go out and check engine stays on.
I'm thinking it's the computer. Anyone have any other suggestions?
Nov 27, 2006 at 8:47 PM
PHILO
  • 6 POSTS
cgrams01 i checked with a local dealer the 1998 cavalier does not have a bcm it does have a pcm of course. apparently the pcm up until 2000 or later handled the functions the bcm handles.
thank you for the suggestion i am going to try a new pcm. anyone have any other advice?
Dec 3, 2006 at 5:52 PM
