1998 Chevrolet Cavailer, headlights wont turn on
1998 CHEVROLET TRUCK
BS5283
1998 chevrolet cavailer, 2.2, 139,000 miles:
when i turn on the switch on the headlights turn on but the parking lights come on, the only part of the headlight that comes on are the drl's. i have played with the wires thinking it was a loose connection, but that has ceased to work. is it time for a new switch assembly?
Feb 27, 2007 at 11:31 PM
CHEVY22
  • 1,375 POSTS
do you have a test light??? check the fuses and the drl relay in the fuse panel under the dash , if all check out ok , there is a blue wire goes into the switch you cna check for power and are the bulbs know to be good?????
thanks , jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
Feb 28, 2007 at 8:50 AM
BS5283
i have checked the fuses and i know the bulbs work because they work when i pull the brights back.....
Feb 28, 2007 at 9:11 AM
CHEVY22
  • 1,375 POSTS
probably going to be the switch then , i would really check the drl relay located in the same spot , if there is another one that looks the same swap them out and retry if all is good replace the switch
thanks , jim
Feb 28, 2007 at 9:23 AM
