1998 Chevrolet Blazer ABS Lockup
Try this site for more abs stuff
http://autorepair.about.com/library/faqs/bl929g.htm
Suggested Repair
Consult a Chevrolet dealer about known ABS module problems on these trucks. As a temporary workaround, the expert suggested pulling the ABS fuse to deactivate ABS. The shop also indicated restricted front brake hoses or a problem higher in the circuit because the caliper pistons would not retract until the bleeders were opened.
Conversation Summary
The owner of a 1998 Chevrolet Blazer reported intermittent front brake lockup, squealing brakes, and ABS code C0265. A shop found that the front caliper pistons would not push back until the bleeders were opened, suggesting restricted brake hoses or a problem higher in the circuit, and the rear pistons would not retract at all. The expert said these trucks had many ABS unit problems, recommended consulting a Chevrolet dealer, and suggested pulling the ABS fuse to deactivate ABS if needed.
