1997 Chevy Monte Carlo Temp Gauge Cycles
3.1L
If I make it out of the car quick enough to check it, I can see it shaking while making the knocking noise.
To help you to get under the hood quicker, have the lovely counter part :wink: in your avitar drive or shut off the car while you are already looking at what is going on.
The cyling of the cool down is probably the fan coming on when your temp is rising to its maximum. If it isn't going into the red or danger zone, I wouldn't worry about it.
The gauge may not be accurate. there is a coolant temperature sending unit for the gauge that may be bad and giving wrong readings? But maybe I'm misunderstanding the concern.
The temp gauge doesn't go into the red zone, but it gets very close and that concerns me. The hose knocking seems to be either the result of the temp getting high, or the cause. I'm thinking at this point of replacing the hose and seeing what happens.
Suggested Repair
Bleed air pockets from the cooling system by opening the bleeders and refilling with coolant. Also check for loose connections on the coolant temperature sensor, and consider a faulty gauge sending unit if readings remain inaccurate.
Conversation Summary
A 1997 Chevy Monte Carlo 3.1L with about 102,000 miles has a temperature gauge that cycles toward hot and back to normal in 30-60 seconds while driving, but not at idle. The thermostat was replaced twice and the cooling system was flushed with no change. The upper radiator hose also knocks and shakes after shutdown when the gauge is high. One reply suggested the fan or an inaccurate gauge sending unit. Another expert attributed the cycling to air pockets and advised opening the bleeders, refilling coolant, and checking coolant sensor connections.
