1997 ChevyTahoe
CRH48
When turning left (more so when there is a bump in road) there is a loud "clunking" noise coming from under the vehicle. Have had it on the rack at 2 repair shops. Everything in suspension front and back has been checked and no problem can be found. One guy said his did the same thing when he drove it off the lot from buying it and never could find the problem and is still doing it. Any ideas??
Nov 29, 2006 at 8:10 AM
JPAM
  • 307 POSTS
looking at some sites it seams like people have been having problems with the sway bar breaking, or inspect the lower control arm bushings for seperation... Some newer problems (newer GM products) i was reading was that the steering column needed some kind of grease fitting put on and greased.... this is what i came up looking at diff. sites
some are for tahoes and some for gm in general... hope it gets u and mechs. some wheres...
jess s
Dec 1, 2006 at 4:18 PM
