1997 Chevy Truck Won't move when put into gear
1997 CHEVROLET TRUCK
160,000 MILES • V8 • 4WD • AUTOMATIC
JAIME82
I have a friend that has a Chevy truck and one day he was driving it and it was like he put the truck in neutral...it wouldn't move. Now the truck will not move when put into any gear. Once in a while you can put it in gear and drive it a little ways then it quits and sounds like it's in neutral again. Do you know what could be the problem?
If it helps we do have a OBDII scanner, hooked it up to the truck and it gave us these codes:
P0740
P0753
P0785
P1860
Thanks
Jaime
Apr 21, 2008 at 6:14 PM
  • 31,937 POSTS
Hi there,
All your fault codes refer to electrical problems with in the transmission, shift solenoids, Torque converter lock up clutch, shift timing solenoid. These problems should be checked out by a transmission repair shop.
mark (mhpautos)
Apr 21, 2008 at 10:06 PM
