1997 Chevy Truck Wont charge
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
KJDRAGON
Ive changed the alternator and battery and i cant keep a good charge. I checked the battery cables and they are also good. If i turn the lights on or heater on the amps wants stay above 9 but if they are off then it reads 9. Im running out of ideas what it might be can you help?
Jan 30, 2009 at 2:46 PM
CALYPSO93
  • 43 POSTS
check all the grounds on the vehicle, and check the wiring from the alternator to the battery, definately sounds like a wiring problem.
Jan 30, 2009 at 2:57 PM
