1997 Chevy Truck Wipers
163,000 MILES • V8 • 4WD • AUTOMATIC
PETER64
No matter what speed I select at the turn signel wiper control arm the wipers on go fast. And when I shut it off the wipers do not return to the lower rest position. Could the problem be with the control module and is it located under the hood or is the problem with the speed selection on the turn signel?
Sep 1, 2009 at 6:05 AM
LOUT5369
  • 217 POSTS
You have a bad wiper switch in the column
Sep 8, 2009 at 12:29 AM
