1997 Chevy Truck stop lights
MEADOWSAM1955
Electrical problem
1997 Chevy Truck V8 Two Wheel Drive Automatic
I took a utility bed off of my truck and installed a used bed off of a '93 model chevy truck.When I hooked up the lights everything worked except the stop lights.The cab stop light does work just not the bed stop lights.
Apr 5, 2010 at 9:13 AM
  • 75,988 POSTS
Hi meadowsam1955, Welcome to 2carpros and TY for the donation-
You need to test the brake circuit from the turn/hazard switch all the way back to the lights the high mount light has its own circuit, doesn't go thru the turn/hazard switch-
The stop light switch is okay otherwise the top light won't come On.
Apr 6, 2010 at 6:32 AM
